PC/PDA problem ... your thoughts please
- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi,
I recently bought a Dell Axim X50v from a member on this board. It's a cracking bit of kit and works beautifully. I've been using it extensively but only got around to connecting it to my PC this afternoon. The kit came with all the bits (cradle, USB sync cable, official Dell MS Activesync 4.0 software, etc, etc).
As per the instructions I installed the activesync software and followed the instructions on how to connect the cradle and device. I have 8 USB ports on the PC, all of which work fine. Whilst finishing off the sync installation I was told to connect the cradle to the USB port, turn the device (PDA) on and insert it into the cradle - the sync software should then recognise it and complete the installation/sync. This is where the problem starts. The software does not recognise the hardware automatically and letting it search for it doesn't turn it up either. So I cancelled the installation.
Deleted the sync software, disconnect the USB cable and restarted the PC and followed the same procedure - same problem, still no connection. I then delete the sync software (again), restart the PC (again) and decide to see if the PC will pick up the USB cradle by itself. Put the USB cable into a free USB port and ... nothing! I have checked every USB port on the PC with my memory stick and they all work properly.
Being a sucker for punishment I decide to go through the process again and this time when I connect the USB cradle a "balloon" pops up from the task bar stating something to the effect of "the deivice is not installed properly and may not work correctly". There is no where to click on the balloon to investigate what's going on and further investigation in the system device manager shows no new hardware or any problems with existing hardware.
I'm now at my wits end. I need to get this PDA connected to the PC in order to (a) sync outlook files as well as (b) install TomTom software on the PDA. It's really doing my nut in.
Anyone have any thoughts or suggestions? I have been thinking that perhaps the USB cradle is defective but it wouldn't appear to be the case as it charges the PDA without problem.
Thanks for your thoughts!
Dan
