A sign in the Bank Lobby reads:
"Please note that this Bank is installing new drive-through ATMs enabling customers to withdraw cash without leaving their vehicles. Customers using this new facility are requested to use the procedures outlined below when accessing their accounts. After months of careful research, MALE & FEMALE procedures have been developed. Please follow the appropriate steps for your gender."
MALE PROCEDURE:
1. Drive up to the cash machine.
2. Put down your car window.
3. Insert card into machine and enter PIN.
4. Enter amount of cash required and withdraw.
5. Retrieve card, cash and receipt.
6. Put window up.
7. Drive off.
FEMALE PROCEDURE:
1. Drive up to cash machine.
2. Reverse and back up, pull forward, back up and so forth and repeat as many times as required to align car window with the ATM.
3. Set parking brake, put the window down.
4. Find handbag, remove all contents on to passenger seat to locate bank card.
5. Tell person on cell phone you will call them back and hang up .
6. Attempt to insert card into machine.
7. Open car door to allow easier access to machine due to its excessive distance from the car.
8. Insert card.
9. Re-insert card the right way with magnetic strip pointing the way the little picture indicates.
10. Dig through handbag and examine each receipt to see if PIN# is written there. Finally, search through phone book to find your PIN written on the inside of the back page.
11. Enter PIN into ATM.
12. Press cancel and re-enter correct PIN.
13. Enter amount of cash required.
14. Check makeup in rear view mirror.
15. Retrieve cash and receipt.
16. Empty handbag again to locate wallet and place cash inside.
17. Write debit amount in check register and place receipt in back of checkbook.
18. Re-check makeup.
19. Drive forward 2 feet.
20. Reverse back to cash machine.
21. Retrieve card.
22. Re-empty hand bag, locate card holder, and place card into the slot provided.
23. Give dirty look to ir ritated male driver waiting behind you.
24. Restart stalled engine and pull off.
25. Redial person on cell phone.
26. Drive for 2 to 3 miles.
27. Release Parking Brake.
Tell you what I find funny about drive-through ATM's:
Over in the US they are common place and when I lived there I used this facility quite a lot. However, on the keypad all the keys have the numbers written on them (as usual) but also in Braille for the blind ... :shock: If you're blind you really shouldn't be driving :wack:
Only in the US of A! :D
