If money was no object?
Everyone lists all there mods but secretly they wish that the mods they have completed were better if only they could have afforded it.
I know everyones vision of the perfect ZED is different I myself can't afford all the things I have I have dreamt of.
so what is your ideal design ?
engine (modded or transplanted)
breaks
gearbox clutch
suspension
bodywork
interior etc
Easy one this........
OS Giken RB30 with 2 x HKS GT3037S and OS Giken 6 Speed Sequential gearbox.
Dribbles :)
My actual list.....
Supercharged V8 transplant
Nissan V8 from Q45
4.5 litre 32v Quad cam VVT - Aluminium block and heads
Headers, Cams, and custom Intake system (Indivdual throttle bodies?)
Emerald ECU management
Dry sump system
Twin Screw Supercharger
Weight reduction - Aim for 150-200kg lighter
New Engine is 100ibs lighter than original engine
Aircon removed
CF tailgate
CF Targa's
CF bonnet
Lightweight seats
Chassis
Half/Rear Polished roll cage fitted
Rear Ladder bars
Front wing braces
Coilovers fitted
Antiroll bars fitted
Polybushes
Foam filled chassis legs
Bigger brakes
Exterior
99 Spec front
Wide arch conversion
New lightweight 18" alloys
2-ton respray (top being black/carbon)
Interior
Carputer install
HUD display for Gauges
If funds allowed, then would love a 6-speed box too....currently looking into the 350z 6speed
**** me. you had to make me write it down. When you write things down they become a goal. Goals must be attained or what is life for. Oh shit Oh Shit Oh Shit my wifes gona kill me.
Jun engine with escort racing manifold, fully chromes and color coded
AEM engine mannagement
Nitros
OS Giken Box/clutch/Diff
Titanium Flywheel
Tomie carbob prop
Greddy 18G's
All redundant systems taken off the car.
HID all round
LED REar
Wide arch body kit
Carbon body panels
Carbon underbody defuser
My Rotora 355mm brakes fitted under Ryker t45 titanium 19" rims
Full roll cage blended into interior
Touch Screen with engine diagnostics and info
Carbon interior with alcantera/leather trim
In car pc for movies, games and tunes.
Cobra Carbon reclining seats.
Painted in teh same color
I am obviously the only one who thinks the Zed is spot on as it is. All I would do is refurb the paintwork and get rid of any rust.
AP Brake setup
Nissan Xeon lighs,
2000 spec (Series R I think) interior.
Total body makeover making it look new again.
Engine
Cryo treated head, block and crank
HKS knock amp monitor
Twin BLITZ SUS air filter
Doolz V2 twin pop adaptor for FMIC
HKS super sqv blow off valves
Twin Jim Wolf Technology Turbos (WZ320-BB700)
Motech stand alone ECU
HKS Iridium spark plugs
HKS Turbo timer type 1
HKS front mounted intercooler
HKS Intercooler hard pipe kit
Koyo radiator
Exedy Clutch kit
MSD Dual coil
Greddy forged pistons
Smithy’s turbo hard pipe kit
Smithy’s radiator hard pipe kit
Braided fuel line kit
Boarder 850cc fuel rail and injectors
Smithy’s mirror finish fuse cover
Smithy’s split/dump pipes
Crower titanium con rods
Greddy metal head gasket
JWT wild race cams
Stillen oil cooler kit
Urethane engine mount
Ported cylinder head
Extrude hone upper plenum
Extrude hone lower plenum
Ported exhaust manifold
Stillen aluminium flywheel
Short gear shift
HKS Boost controller EVC4
Unorthodox racing under drive pulley kit
NISMO radiator cap
APEXI grounding kit
Twin Bosch fuel pumps
Stillen headers
Stillen battery tie down
Carbon fibre drive shaft
JUN valve springs
JUN valve guides
JUN strengthened fork pivot
Brise competition alternator
Cusco master cylinder stopper
Braided Brake fluid lines
HKS extreme timing belt
Aqua mist water injection kit
Full custom race exhaust
Nitrous
2X Optima yellow top batteries
Stainless steel power steering tank
Stainless steel fuse box cover
Chrome balance bar
Braided clutch lines
Nismo oil cap
Boarder racing radiator fan kit
Stage 4 porting on head and block
Boost cooler
Cusco intercooler sprayer
High flow oil pump
Nismo Crank
Ferrea Valves
HKS Fan controller
High output oil cooler
Cusco brake master cylinder stopper
Splitfire DI Ignition
AMSOIL Dahl Water Separator ADF-20
Chassie
KAAZ - LSD
Border Racing brake kit
Stillen Front strut brace
Stillen rear strut brace
Race logic traction control + Launch control
Windscreen washer fluid heater
Volk racing Gram Light Pro 57
Toyo Proxes T1R
Tein Flex with EDFC
Cusco Tension Rod, Camber Kit
Top Secret Roberuta Cup Kits
Exterior
Evolution R Body Kit
Carbon fibre M3 wings
Veilside aero mirrors
HID upgraded headlights
NISMO Fuel cap
Carbon fiber bonnets
Carbon fiber slam panel
Air guide slam panel
Headlight covers
Carbon fiber drift spoiler
De-bagged de-locked
Lightweight glass
Chrome headlights
Matt black re-spray
Clear indicators
Blacked out rear panel
Complete waxol of under carriage
Carbon Fiber targa tops
LWRRP FRP Doors
Border Racing GT-Air Flaps
Interior
Z Center 6pot dashboard mod
Z Center radio slot gauges
Veilside 300MPH Speedo
Carbon fiber dash kit
Carbon fiber speed surround
Chrome dial surrounds
2X Cobra MISANO PURE CARBON BACKREST with custom fairlady z logo
Chrome seat brackets
Velvet head lining
Custom 300zx TT floor mats
NISMO gear knob
Stainless steel pedals
Momo steering wheel
300zx.co.uk tax disc holder
Tinted rear windows
Nokia Bluetooth phone kit
Road angel
Carbon fiber door cards
Full leather re-trims
Chrome door handles
Chrome roll cage
Door controlled neon lighting
2x Greddy boost gauge
Greddy oil pressure gauge
Greddy oil temp gauge
Greddy water temp gauge
Greddy fuel pressure gauge
HKS exhaust temp gauge
D-gauge tachometer
D-Gauge manifold pressure gauge
Voltmeter gauge
Complete waxol of cavities
Full sound deadening kit
Blue LED dash conversion
Carbon Fiber dash vents
Carbon fiber dash surround
ICE
Kicker KQ30 equalizer
Kicker KX3 crossover
Kicker Solo X 18" sub
Kicker KX2500.1 (amp for sub)
4X Kicker es693 (6X9's)
Kicker SX900.4 (amp for 6x9)
2X Kicker ES65.2 (Component)
Kicker KX350.2 (amp for component)
2x Kicker KS25 (Tweeters)
Kicker SX600.2 (amp for tweeters)
Carputer molded into double DIN slot
Pair of RCA splitters
engine or car?! :rofl:
The whole thing
Lets be serious if money was no object the zed would be pampered and as new, but just an every day hack and I'd have fleet of exotica to drive a long line of hot gold digging bitches around before driving in them and then driving them away :rofl: :rofl: :rofl:
FOOK ME
You had better hope for a roll over
:rofl:
Engine
Koyo radiator
Exedy Clutch kit
MSD Dual coil
JWT wild race cams
Short gear shift
NISMO radiator cap
APEXI grounding kit
Stillen headers
JUN valve springs
JUN valve guides
Nitrous
Chrome balance bar
Nismo oil cap
Boost cooler
High flow oil pump
Nismo Crank
Ferrea Valves
HKS Fan controller
Chassie
KAAZ - LSD
Toyo Proxes T1R
Tein Flex with EDFC
Exterior
NISMO Fuel cap
Headlight covers
De-bagged de-locked
Lightweight glass
Chrome headlights
Matt black re-spray
Clear indicators
LWRRP FRP Doors
Interior
Velvet head lining
NISMO gear knob
Momo steering wheel
Tinted rear windows
Road angel
Chrome door handles
Chrome roll cage
D-gauge tachometer
Voltmeter gauge
ICE
im greedy so my list is very very long but im more the power and control type than bodywork.
i think i'd go for a subtle bodykit just to set it off (veilside skirts, etc.) no big wings or mad bumpers, just a little smoother and more pronounced.
then....
a multi-link racing suspension set-up on a one off tubular chassis with integral rollcage, 2x T-88 or T51R's, wiseco/JE/etc ultra low comp pistons, full JUN 3.2 stroker bottom end, dry sump conversion, 2x race oil pumps for the engine, seperate oil pump and resevoir for the tubs, solid state (no timing adjust), higher lift cams, vernier pulleys, titanium (larger) valves and dual springs, solid lifters, EGR blank, 2x high pressure water pumps for the engine, seperate tank and pump for the turbos, all oil, water, p.steering pumps, etc alloy, all lines braided, no balance bar, ported/polished heads, one off exhaust manifolds to the relocated turbo's, one off (seperate) intake manifolds, 2 rows of injectors (one smaller than stock for bimbling around town off boost and the other 880's or so), top range ECU (dont think it really matters which one - i think the set-up's more important), dual external wastegates, 2-2 exhaust (no link in the middle), 2x high pressure fuel pumps, 2x electronic fuel pressure regulators, 1x low pressure fuel pump into the surge tank, 2x huge chargecoolers with CO2 spray, tripple stage nitrous oxide with one to keep temp down on low power gain, one big one to get the turbo's spinning before boost then a bit less but still decent while they do, 2x huge radiators (one in the front, one in the back), 2x huge oil coolers (one for the engine, one for the turbo's, faster steering rack, adjustable camber, leather seats, fresh paintjob, nice wheels (19' ish), VFD dash, organic/ race clutch, carbon/titanium driveshaft into the porsche G50 transaxle, AP/Brembo to do the stopping with massive disks and ducted cooling pipes to the brakes, standard Z climate control cuz its bloomin good.
dont know if i missed anything but im sure i did. like i said, i'm a greedy guy.
BTW, if anyone wants to sponsor me to get this Z built........ LOL
oh, and about 60psi would be nice.
still after sponsors :o)
If i was to keep the engine as a 300zx engine then:
Custom lined cylinders to allow for a 3.4 conversion
Custom 290 degree 11.5mm lift cams
Custom Solid Lifters
Jun Crank
Escort Pistons & Rods
Escort Front Manifolds
2 x GT30R Turbines
Custom Rad and Intercooler
Skyline OS Giken 6 speed Seq Box Bolted to Uprated Skyline transfer box (front diff removed and plated) to custom shorter drive shaft (carbon of course)
Direct 100 NOS for spool
All linked into AEM ECU
All in a SWB Slicktop, fully stripped with a stack dash and not much else
Alcon 6 pots up front Alcon 4 pots on rear
Gram light wheels with toyo 888 tyres for road
Loads of other stuff ;)
Mike
Jun Crank
2 x GT30R Turbines
Mike
so whens that gonna be on the road then? you've done pretty much everything else!
1 x rocket engine to GO
1 x parachute to STOP
me sorted :D
Purple Ronnie:
Updrated Front Mounted single intercooler
Apexi Air Filter
Chipped and tuned
Stainless box front to back (w.i.p.)
Twinz front bumper
6 speed 350z box
Black leather with purple stitching retrim
Custom Dash (work in progress)
18" Speedline 3 piece split rims (w.i.p.)
Custom sound install (w.i.p.)
2nd project
Drop top shorty
4.2 V8 with supercharger
Racing suspension
Lightened
Headers
It's a dream i know :D
