Leaky tap
Not in the Zed - in the bathroom - the hot tap drips.
I can turn off the hot water but does anyone know how I take the tap to bits?
Does the top just screw off or will I need to unbolt it somewhere?
Cheers gents!
:hyper:
first off - check if there is a cap of some description on top of the tap ( screw or push on) these normally hide a screw - undo screw lift off tap head and put spanner on the main body of the tap - this should undo. check washer and seat
any help??
Regards,
alex
post up a pic if you can't get the top off.
Thanks chaps
I took a photo but can't resize it right now.
I managed to take the top of the tap off - it just lifts off and I can see the main body of the tap.
I'll try and get to the washer.
Many thanks for the help.
Cheers!
Tim,
Id just get Neil Morris to visit!!
He's the best plumber in the east :D
if its a qauter turn tap, its probably fooked, you can but new inserts though
just find out what make tap it is or take it along to a plumbers merchants and get them to get one for you
Tim,
LOL, he's probably off the the Carribbean again.
