Project "More Boost"
Well got underway today, unfortunatly we got rained off so didnt get the engine and box out but got a load of other jobs done like the trashing of the air con etc and its ready to be lifted first thing tomorrow :)
Border Front Mount
Trust Oil Cooler
Air Con Gone
Hopefully the weather will be better tomorrow as its pi55ing it down now :(
Mike
  • Replies 78
  • Views 3.8k
Heres the pics of the spacers, longer hub studs and lightweight nuts :)
vbgarage.php?do=getimage&id=3193
vbgarage.php?do=getimage&id=3192
Mike
Mike
where did you get the longer hub studs and lightweight nuts from bud :rolleyes:
Hi Matey
Got them from chris@getgreddy ;)
Mike
how much mate if you dont mind me asking?
well the nuts come as a kit, will dig out the invoice and the spacer/longer studs came as a kit as well and again not cheap mate but what is for a zed :tongue:
Mike
Well not much done this week due to weather and was hoping to get my border rail and injectors to finish it but they should be here monday now so gona be mid next week till its finished.
Got a few jobs done in between the rain and snow ;)
Finished relocating the battery to the boot
And fitted my catch tank, before anyone says, yes i know the plate the battery fits on is a little rough but dont worry it will be sprayed very soon to spruce it up :)
Mike
Looking good mate.
I have a lot of problems with my air filters mounted in a similar position to yours.
It's fine when driving but when stood in the rain water pours in all around the headlight panel and soaks the filters.
Might not be so bad with those but on the Apexi's they don't allow any air in when wet and the car won't even start.
Trying to reposition mine at the moment but with the Doolz setup I've got I can't see any way of doing it.
You'll probably have to make some kind of splash guard above to stop them getting drenched.
Strange thing is it's not a problem even when driving in heavy rain.
Really interesting pics guys, seeing how this wonderful engine goes together. Being new to 300's it's great to see pics like this.
Good luck with it all Kirbz :D GUMBALL :cool:
Nicccccccce :cool: ;) :D
what cabling did you use to get the battery in the back mike? is the stuff from demon tweeks gonna suffice, and are all the earthing points now in the boot?
was gonna use the space for an expansion tank
edit - ooh, ooh and is the catch tank replacing the pcvs?
cheers!
cheers!
I went to my local aut electricians and bought some proper cable, cost me about £15 for 5 meters.
Yes the engine will still be earthed in the same position and i am having several earthing positions in the boot.
Yes the catch tank pretty much replaces the pcv valves :)
Mike
Well nearly there!! just need to wire the maf up which is easier while the engine is out and were ready to fit the engine back in :dance:
Just need a few dry days.....please a few dry days :p
Border Rail!! looks lovely and with the plenum on you cant see it :rofl: hidden bling
Mike
:bow: :bow:
awesome!
Very nice, but even more impressed that the windscreen scuttle panel isn't cracked :rofl: :D
it is cracked :rofl:
but i have my old one which is perfect to go on ;) :tongue:
Well today has been pretty constructive.
Some of the studs on the downpipes had stripped off when removing them so replaced all them.
The border rail takes the fuel lines right to the back of the plenum and takes them right next to the hard water pipes so i had to have some 90 degree fitments made up but its all on now :)
Fitted my 99 spec lights, centre panel is on its way but still looks niles better.
Removed the carbon canister etc!! you should see how much crap ive removed from the car ;)
More importantly we test fitted the engine back in to test the custom stainless pipework we have put in and the RHS is perfect, the LHS needs a little work so ive had some more stainless bent to the right amount and just needs cutting to make it all fit :)
So tomorrow, weather depending we should be putting the clutch and box back on and fitting it back into the car so the car should be running by the weekend :)
Thanks god :p
ya goin to be running it in to the meet on sunday? looking real good there kirbz
unlikely as it will still be running a map on 555cc injectors and will have 850cc's so i dont know how well it will run :(
fingers crossed should be all done in 2-3 weeks ;)
Well after a whole day of trying to get the gearbox lined up and giving up pi55ed of and cold went out this morning and went on straight away :smw:
So just broke for lunch and putting back in later :hyper:
like that sometimes on a manual they just slide in other times it can be an arse :rofl:
yeah, its a well known fact if you stop for a coffee it will go straight on!! :D
problem was with having a triple clutch there was 3 splines to get 100% lined up!! in the end we fitted the clutch, lined it up but left the clutch loose then fitted the box to line it up after each plate but turning the prop in the back and once it all lined up we carefully removed it nipped it back up, tried it again and hey presto :)
Engine is in just connecting it all up now, so should be all conected up etc tomorrow or monday
nice one its bad enough with a standard clutch let alone triple plate
yeh coffee break normally sorts it :D
