any ice gurus out there?
right my question is how do I connect a power cap up?
according to the instructions - terminal to ground
+ terminal straight to battery and to the amp
but this means the power cap is on all the time meaning flat battery :confused:
where as the remote wire switches amp on/off so this doesnt drain battery
cheers guys :cool:
The cap is on all the time but only supplies power to the amp when it needs it. It`s like another battery sitting there but only gets used when you turn the amp up and get a voltage drop, the cap then supplies any extra power reqd.
Bob
cheers mate
connected it up the way I have said but flattened my battey?
Have you charged the cap up? some come with a resistor you use to charge it with the engine running.
Bob
nothing with it bud
shows 14 on digi display but drops after a day or so if car not used
what make is the cap ,, will do some searching for you , ive had three of these and they connect different ways they should have a remote connection to only allow them to turn on when your stereo does, but not all do , cheers give us the farrad , ie 1.5 .1.0 etc and make and i can help you out ,,
cheers bud make SFX 1.5 farrad
Hello
I saw this thread and asked my partners advice as he instals audio equipment, his reply was " use a 5watt sidelight bulb connect the earth from the battery to the cap and wire the 5w bulb in series between the positive battery terminal and the positive terminal on the cap, once the bulb goes out, your cap is fully charged, doing this without the bulb or resistor will damage your cap"
Hope this helps as i have no idea what that meant
Tara
Hello
Tara
Thanks :cool:
I use to run a cap in my old car and to be honest if your wiring is spot on you wont need a cap unless your running atleast 3 amps, if your power and earth connections arnt great though a cap can be useful to prevent things like your lights dimming when a bass beet hits. My cap just charged itself up and then it turns itself off 10mins after you turn the ignition off. No remote lead was needed. I used a distribution block and had 2 amps and the cap in 1 end (all 4 gauge cable) and the main power in the other end (again 4 gauge). Never had any problems. If your battery was drained check your earth connections again.
could you not use a relay with a remote wire from your stereo/ignition so it's only charging then?
Vijay
