wats the best to use
what is the best fluid to use in your rad over the winter period,
Any high quality AF, make sure you use 50/50 ratio as the anti corrosion inhibitors only kick in at that ratio!
i have just purchased a koyo rad how much AF should i put in and what sort of AF should i put in.
Any high quality AF will do, the expensive Halfords AF or castrol AF seem good, mix the water AF before you put it in and then you know you have the right quantities.
thx mate
