Whats the best adheive for sticking mesh??
Stickoflex, available from car paint suppliers
why are you sticking mesh? is it for strenth or fixing?
Yep, are you using it as a base to bridge a hole which you'll fibreglass over or are you running it across a vent/airdam to prevent crud flying in!? ;)
Mind you, either way I'd apply the mesh to the inner side of the hole/vent, making sure you've cut it so it's about 1-2cm over the size of the opening then fix it in place with activated resin or filler.
Leigh
No More Nails works too !
Excellent this is what i have bought to try. Oh by the way its for sticking mesh over the holes and vents to stop crud flying in.
no more nails is pants I have found, what you want is gripfill in the green tube- comes in 2 sorts, solvented and non-solvented the solvented is the best. once it has set it goes off like rock.... you can get it from your local Travis perkins.. just my pennysworth...
I cut some 2" lengths of welding rod and fibreglassed them on the back of the bumper that way you can poke the rod through the mesh and bend it over then remove it when you want
Hot glue gun........the profesionals choice hhhhhhmmm not for much longer though!
yep no more nails is shite takes to long to go off best is gluegun as it cools and goes off quick gripfil as speedfreak says is good to
I bought some evo stick stuff called Serious stuff extra strong adhesive. Sounds the *****cks so i hope it is as good as it says.
