Just picked up my new Z...
...and it's a mixed bag, but mainly good. Car was recently imported and needs a bit of tidying up.
It sits very low, put it up on a ramp earlier and it's immaculate under there! Also runs on aftermarket suspension which is adjustable at the rear, nice touch, but I clicked it up a notch as it was too hard!!!!
There's also a noise coming from the rear, thought it was suspension related but everything was ship shape at the back. Might be me, unless it's just the noise the shocks make when going over bumps, doesn't do it when bouncing the back of the car.
Think there is a heat shield or something loose as it rattles at about 1500 rpm then goes away.
The dash squeaks a lot and I have to get this sorted, tried tightening all the screws I could see but no joy. Short of taking it all apart I have no idea how to stop this.
Couple of minor bits on the body work need sorting, front bumper and t-bar/windscreen strips
Now for the engine, sounds sweet enough, the guy said it just had an oil change and it looks good, he used 5W40, will this be OK? Pressure gauge seems a bit intermitant but read that it's more likely the gauge than anything else.
Oh the important bit. It's a 1994 non turbo manual in blue, loving it. Bloke was in the middle of moving so took a lowish offer, I was well pleased.
Done 200 miles earlier, fun fun fun
Id use at least 10-40 for the 300 IMO 5-40 is a bit thin
welcome by the way :D
rattles on the z is common put a screw in the ashtray and you will think somethings wrong :wack: its normal for rattles within reason,its normally something daft like a screw loose!!
as for servicing z tech is a popular choice :D call ryan on 07968166640 handy also for any parts you may need reasonable cost and v good service aswell,im biast as i work there
infact your just up the road z-tech is in baydon[marlborough]
so thats what you call it. i thought you were just sun bathing.
btw car looks good the the metal mate v good
smile'es no workie
