Well chuffed
As some of you know i blew my engine to bits on saturday, after my oil pump seized - i was totally gutted
Now managed to source an engine with 32000 miles, for £400 - well happy. Gonna get some Jun cams shipped and fitted too
Im over the moon - thought my z would be off the road for ages, looks like it will be a quick turn around now (2 - 3 weeks)
Just thought id let yall know
Well done mate, im chuffed for you.
there is nothing worse than that feeling that its all gone tits up...
i hope the work goes without a fault mate
Were there any symptoms before your pump went? Was you oil pressure low? Just seems on here low oil pressure on the stock guage is ignored, just wondered if there gonna be few more engines go bang soon.
Don't say that! NOOOOOOOOOOOOOOOOO! :headvswal
lol
Yea oil pressure gauge was reading low - and i though - it will be ok
LOL
I advise everyone readingf low oil pressure to get it checked asap. It might last ok around town, but as soon as you give it some beans it will pack up - then starts the trouble
I was an idiot for not checking it, and im paying the price
Congrats, glad to hear its on its way to being sorted :D
Everyone....Aftermarket Water temp and Oil pressure gauges !! ;)
Well I am glad you got everything sorted mate.
Best thing that anyone can do is get an aftermarket oil pressure gauge fitted, or replace the stock sender so at least you will get a accurate reading. I have fitted oil temperature and oil pressure guages .. just my 2p worth.
Chris
Deffinatly both of those - my water temp gauge deosnt register anything above half - even when it nearly blew up.
When you buy a Zed that should be the first upgrade
I'm getting mine connected up on the 28th May, I hope it's okay... fingers crossed
I cant fit any more gauges in my ride - already got water temp, Nitrous press, and voltage - where else can i put them without looking like a tit in a cockpit lol
Last time Sarah was in my car she said it looked like a aircraft cockpit ... LOL
I then went on to explain why all the gauges were there and what purpose they served. Funny thing is she spent a lot of the time watching the gauges ...
She then said "Why do you have to keep accelerating so fast?"
I replied . "Because I can"
Boost, Oil pressure, Water temp, Volts
vbgarage.php?do=getimage&id=568
Recognise the Pillar-Pod Chopper ?;)
In the center consol, i got safc, DVD and head unit - so no bloody room AHHHHHHHHHHHHHhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Maybe, ill just wire datascan up to the dvplayer and have every gauge known to man loll
Now you're talking ... I would .LOL
forgot about the datascan, yep I have mine on permantly in the car on the in-dash screen.... so thats
Oil pressure
Boost
RPM
Air Flow
Water Temperature (C or F)
O2 Sensor
O2 Sensor Right Hand
Speed
Battery Voltage
Throttle Position Sensor
Injector Time
Ignition Timing
AAC Valve
Air Fuel Base
Duty Cycle
LOL....it should do ;)
Oil pressure
Boost
RPM
Air Flow
O2 Sensor
Speed
Battery Voltage
Injector Time
Ignition Timing
AAC Valve
Air Fuel Base
Duty Cycle
oil temp
egt left bank
egt right bank
fuel pressure
turbo timer
suspension dampening rate
bank balance indicator
distance to next fuel station
is it vince with all of these - fook me his interior looks like an F15 - step forward vince or MAC1 who i know has a piccy
Regards,
alex
