NZR - 15v psu
I want to use an old Libretto inside my Z. The power supply output is 15v 2a. What would happen if I had a direct supply from the cig lighter? With the engine running it's up just over 14v, would that run it?
Vijay
probably yes, try it in a different (somebody elses) car first though to make sure it doesnt blow the fuse ;)
like clarkey said it may well work,
make sure you run an inline fuse (2amp if thats the output of the laptop power supply) between the fag lighter power and the laptop itself just incase!
