paint - how much
Hi,
Just wondered how many litres/pints are needed to spray a z?
Vijay
Hi,
Vijay
:duffer: £1500.00 as it is a Zed £59.00 for a mini.
P.S. got the new batterey ( Lucas 72 amp £52 ) :bow:
To be honest it depends on what type of paint you are going to use, how many coats you want to put on and wether you want to do all the engine bay door shuts etc.
3 litres will be sufficent unless your going for flip which will require a base coat, usually black.
3 litres should be more than enough.
Dont forget that you mix it with thinners, which would could double the amount depending on the recomended mixture
