Must have missed this - blimey, look at the mods list!
http://www.sxoc.co.uk/vbb/showthread.php?t=119248
This really is about the worse thing I have ever had to do but I have no other option now but to sell my car due to circumstances out of my control. It is a white '93 S13 Personnal Reg "K550HP" with full ND development to circa 630bhp. The car has had everything needed doing at no expense spared with over £75,000 spent on it to date, recipts to prove. I will also be letting the car go with 29, 18" tyres of various compounds, 8x Kahn RSR 18" wheels, 2 drag radials with custom Compomotive MO rims, Motec laptop and software for mapping, lots of other spares including airfilters etc. I have lots of photos and video's but serious buyers really need to take a few test drives. Open to offers around £24k.
Tech Spec:
Performance: -
0-60mph 3.56sec
0-100mph 7.419sec
60-100mph 4.07sec
0-150mph 15.8sec
Engine Mods:-
CA18DET 1809cc Turbo
9000Rpm Rev Limit
Best Top Speed So Far 186Mph
ND Forged Low Comp Pistons
ND Chrome Piston Rings
ND Metal head gasket
ND Lightened & Balanced Bottom End
ND Prototype Flywheel & Clutch
ND Steel Billet Crankshaft
Trust Steel Conrods
ND Lightweight Solid Lifters
Tomei 260 Solid Profile Camshafts (Currently HKS 264 cams)
Tomei Wide Coil Valve Springs
Tomei Adjustable Cam Pulleys
ND Race Spec Cylinder Head (GT Combustion Chambers)
ND 1000cc Fuel Injectors
Full Dash 8 Fuel Lines
ND Large Bore Alloy Fuel Rail
ND Prototype large bore throttle
Modified throttle pedal
ND TPS
ND Prototype inlet Manifold (3" Inlet)
ND Prototype plenum
SARD Adjustable Fuel Pressure Regulator
Bosch Motorsport Gp B Fuel Pump
Motec M4 Pro Ecu
Motec Launch Control
ND Full Engine Management System Loom
Bosch Idle Control Valve
Full Greddy Turbine Kit TD06-25G
Modified Low lag 25G turbo 360* oversize thrust bearing
Greddy external wastegate
ND Prototype Rad
Stant High Px rad cap
Mocal oil cooler system
Remote filter housing
ND Prototype Front Mounted Intercooler
NX N-Tercooler
3" Intercooler Pipework
Samco Blue Hoses
Cusco Catch Tank
ND Breather System inc Sump Return
8.0 To 1 Compression Ratio
AEM CDI
ND Coil pack
HKS 40i Plugs
K1 Racing Leads
Apexi Filter
4" RB Alloy Filter adaptor
HKS Super Dragger Full Exhaust System
3" Turbo back exhaust
3 Bar Map Sensor
Nismo oil filler cap
Remote Mounted Battery
Alloy BatteryCover
ND rocker cover
Polished cam cover
Polished PAS tank
Transmission:-
OS Giken Long Ratio Gearkit
OS Giken 600bhp+ Mainshaft
S14 rear housing
ND Twin Plate Clutch Assembly
ND Quickshift Kit
Interior Mods:-
Greddy 60mm EGT
ND Boost Gauge Kit
ND Oil Pressure Gauge
Nd Oil Temp Gauge
RB Alloy gauge mounting plate
Weber Alpha Lambda Monitor
Greddy B Spec Boost Controller 2.5 BAR
Greddy Turbo Timer
Sparco Bucket Seats
Nismo gear knob
Momo millenium steering wheel
Momo boss
Nismo Key
Luke 3" Harnesses
Stripped rear chassis
Chassis Mods:-
Leda 2.5" Race Coilover Suspension Kit
Nismo Rear Sub-Frame Bushes (X 4)
Lowered 80mm All Round
Whiteline Front anti roll bar
Solid Steering Bush
Lightened to 1100kg
Brake Mods:-
ND 355mm Front Brake Kit
Goodridge Braided Hoses
Mintex Synthetic Brake Fluid
Mintex F4R Front Pads
DS2500
ABS Removed
Wheel Mods:-
18" X 8" Khan RSR's x4
Dunlop D01J 235/40/18 Tyres for racing
18"x 7.5" Khan RSR's x4
Avon ZZ1 225/40/18 for road use
15" X 10"Compomotive MO's
BF Drag Radials 26" X 10.5"
Ice:-
Clifford 600 Alarm
All Ice removed
Exteria:-
Jun front bumber
Jun side skirts
Eiribuni rear wing
Jun rear 3/4 panels
Various decals
Personalised plate
Coming soon:-
32psi boost px
Stats:
BHP 532.6@hubs @28psi
Torque 484lb/ft
0-60 3.56sec
Qtr Mile 11.4@ 129mph +7 IGN ADV
Top Speed 207mph @9000rpm
__________________
0-100mph 7.419sec
http://www.norrisdesigns.com
That's sad :( Very sad..
It's hard to part with cars you love, parting with that one must be like tearing off a limb.. Heck, I can't bring myself to sell my cantankerous old girl, even though I've got nowhere near enough cash to sort her out..
Shame :'(
