Transmision Fluid
Recently I fitted loads of new bits inc water pump etc and had to take the rad out to get to everything ok.
There were two hoses at the bottom of the rad which were loose, I took them off and replaced the clips as they were knackerd.
It looked like transmision fluid was leaking out of them or similar, any ideas? put it all back together, and an after thought was that if this is, then perhaps it may now have an air bubble in causing the box not to work as well as it should???
I havnt test driven it yet so cant tell, tomorrow will be the first drive before billing so I hope it all goes ok.
Any ideas on the stuff comming out and if tranny fluid will it have caused a prob? the level seems ok still.
The Two Hoses[about12mm Diam]should Go To The Cooler Spigots On The Side Of The Rad,if U Checked The Tranny Level After Removal
And It's Ok,then No Probs-this Is Assuming We Are Talking About The Right Hoses? Hth ;)
Ahh cool, yeh they are the ones I'm sure, hopefully its all ok then.
