Kin 'ell, Mondeo brakes - what a PITA!
Hi
Changed the discs and pads on my mk1 mondeo last night, what an arse of a job.
They were well and truly seized on for some reason :confused: I had to use an angle grinder in the end (after having tried a sledge hammer, a huuuge axe lol and a crowbar to try and remove them) and cut the fookers in half till they freed up :dance: Then smash them off with a lump hammer.
Took me the whole evening :rolleyes:
Whats the most PITA job you've done thats supposed to be easy?
Pete
Replacing the bulbs in the high level brake light on the Z
:mad:
One of the bolts had corroded and was stuck solid, mashed the head :( I had a spare light so I broke the old one off, only to be left with a big lump of plastic around the bolt and I still couldnt get anywhere near it! ended up blow torching the F****r. burning off the lump of plastic then taking the bolt out with a pair of pliers
2min job I told the missus... 1.5hrs later she's still standing tapping her feet waiting to go to shops :rofl:
LOL Yeah the missus nagging in the background ("dont get sparks on my car etc... " lol) doesnt help does it!
I did that same job at Billing last year and Cos had a magical screwdriver which removed it, when none of mine would work lol.
I think the water gets under there and rusts the screws, bad design
trying to fit a very thick power wire from the engine bay into the cabin to run an amp. Had to take the battery out and drill through the bulkhead, very tight to get my large drill in, five drill bits later, a scratch on my wing (bas%*rd) and a lot of swearing the job was done. also just trying to get the damn thing to run properly, still isnt!!!!
Cough........I think someone else was there......cough.
Cheeky git.
Try doing yer rear wheel bearing on the Zed then....ferking b*stard of a job....it had been on since manufacture so tight as a nuns c*nt...took best part of 4 hours to dismantle...handbrake pads exploded as I took em apart so like one of them puzzles you get at xmas!!! (anyone need them done then I am the one!)
4 hours to get it back on as did'nt have a spring compresser for the rear coil spring, and the the bearing is 120 quid!!
Best weekend I had in ages!! :nono:
Hi
Pete
Had the same problem on my Xantia. Exteme violence was required !
Both the stupid little screws holding the discs in place had seized, refused to budge with the impact driver and had to be drilled out, then the discs had seized to the hubs which took major input from the lump hammer to shift. Dunno how much damage I did to the bearings !
