my car keeps going into saftey boost (code 34)
i dont want to desconect the detonation sensor
if i fit a jwt chip
will this sought the problem out
it was runing at about 14 psi
now its runing at about 8-9 psi
steve
no, a jwt chip will still go into safety boost with the stock solenoids.
safety boost is 7psi BTW, are you measuring that on an aftermarket boost gauge or the useless stock one?
Paul - if its got boost jets to raise the boost, wont safety boost be higher than stock safety boost :confused:
Pete
U'll need to have an aftermarket chip to run 14psi how did u do that before and how did u measure it like Paul asked u before?
Pete
nope, safety boost on boost jets is still 7psi. that one reason i like boost jets! stops me driving it like a nutter from cold!!! :D
Yeah Paul is correct - boost jets will still give you 7psi under safety boost conditions, however that will have slight boost spikes on WOT....
Code 34 is because the det sensor/harness is FUBAR. A new chip won't go into your engine, replace your det sensor and harness, then get back into its cossey socket in the ecu ;)
it was run 14psi with 1mm mig tips
yes i have an after market boost gauge
i no that a chip wont repair the detenation sensor
but will it reduce the chance of deternation ?
i thought i read somewhere that it would
thanks
steve
ok, yes - you should fit an after market chip if your running that much boost, BUT - code 34 means the sensor or wiring is faulty. so you will still get code 34 & safety boost with another chip.
so all in all, you need to repair the wiring/det sensor AND get a new chip!!
Hello Steve,
If I was you I would get your car running right with no error codes before you start worrying about upgrading anything, it's not worth taking any risks................
The JWT chip doesn't have a safety map so if your car attempted to go into safety boost, it wouldn't change any settings.
Vijay
i have reset the ecu
and disconnected the battery for a couple of hours
i have unplugged the det sensor connector and its back to 14psi
so whats the next stage
there seems to be a similar plug under the one i have unplugged
should i look at the wires on that as well?
thanks for all your help
steve
CANT GET MY HEAD AROUND THIS ONE
cleaned all sensors
reset ecu and disconnected battery for 2 hours
went for drive car was hitting 14psi
then after about 20 miles it went back into safety boost
code 34
now if the car was deting would it go into safety boost
if so for how long and what code would it give
sorry to keep posting about this
steve
it could be that the sensor or wiring is heating up and failing. Code 34 is not detting - it's the sensor circuit.
I would reset everything and then do the same sort of journey without going into heavy boost (don'y go more than 9psi) and see what happens. If it still happens (which it probably will) I would do the resistor trick and again do the same journey, sticking to under 9 psi and see what happens.
Vijay
code 34
FFS, try reading my reply then post again!!!!! :xxx:
thanks mate
if i disconnect the sensor is that the same as the resistor trick?
steve
here it is again in case you missed it!!
i didnt miss it
but what i was asking was if a car was in safety boost what fault code would it read
steve
ok, but im not sure what you cant get your head around still!!, youve got code 34 stored in the ecu, this is telling you the car has a faulty det sensor or wiring.
the ECU has now way of telling if the car is detting or not so it puts the car into safety boost.
there is no "code" for the car detting, the det sensor is there to listen to det & back of the timing and/or boost if it detects it.
so were still back to you having a defective det sensor/wiring that needs repairing!
thanks
i was confused about code 34
i was thinking that if the car was deting it would go into safety boost and read code 34
but that makes it clear that it is just a sensor failure not a detination problem
steve
thanks mate
steve
No, this will not work. The ECU looks for the impedance of the sensor which is a pizo device and has a resistance of about 1MOhm, hence the 1MOhm resistor.
after going out in your car tonight stevo i was still impressed even though it was not running to well cant be that much of a problem to sort out
everything seems fast compared to a gt4
see you tomorow mate
i dont need a lift in the morning mate.
steve
ok mate no worries
