protoj · Tuesday at 18:48 4 days
I've just tried changing the display order so newest posts are at the top ... it's quite good reading it that way but you then have to scroll all the way to the bottom to move onto the next thread!
Could we have a duplicate of the next/previous links at the top of the thread too? Save a bit of wear on my ctrl-end keys. ;)
