BP Ultimate Crap
My usual shell garage was closed yesterday so could not get hold of optimax , just up the road is a BP so I put in some of there Ultimate , within 10 mins car is detting at 14.5psi and generally not driving how it normally does, had to turn the boost right down to 12.5 psi to stop detting , what a load of crap not impressed at all.
Bugger, cheers for that, I wont be using that then.
Buy a bottle of octane booster and keep it in your boot for those unavoidable times you have to stick farmers petrol in ;)
Can anyone suggest some octaine booster that works as I know there is a lot of crap out there :confused:
Millers
In its defence. I dont think fuel from the tank will reach the engine in 10 mins. Plus how much fuel did you have in when you put Ultimate in?
Stu I had done 6-8 miles after putting the new petrol in and the tank before filling was very low like between 1/8 and empty
i have a similar problem, but with optimax... I normally use ultimate and as soon as i put optimax in my cars detting all over the place. Is it the way the ECU is set up or is it just one of those wierd zed things?
Wierd! :confused: Does the ECU self-learn to use the cars usual petrol then? But surely going to a higher RON shouldn't cause detting if 97 was ok??
You say normal LOL but it hasn't been out that long... ;)
Good point, before that i used esso super unleaded and it was the same thing. My car just hates optimax!!!!:confused:
Don't the ECUs have to learn "new" petrol? The MR2's used to... specially when the engine is tuned.
My N/A loves Ultimate and I'v been useing if for at least six months. would'nt use anything else..:dance:
