What mods have you got?
Nice to have an update :)
Mine
Stillen intake
Mongoose quad exhaust
SS Decat pipes
HKS ALC
Momo Race steering wheel with CC boss
JD chip
Boost @ 12psi
Colour coded engine bay
17" R33 GTR V-Spec alloys with Goodyears/Bridgestones
Smithys clear side repeaters
Smithys SS top rad pipe with sender
Smithys braided fuel lines
Panasonic/Infinity ICE
Front and rear strut braces
Cusco rad cap
Nismo oil cap
Samco boost/intake hoses
Big uprated autobox oil cooler
Stickers here and there
Autometer boost/water temp/oil pressure gauges (not fitted)
Goodridge brake lines (not fitted)
What about you?
:dance:
  • Replies 54
  • Views 2.8k
limited edition Apex'i big hole in floor to throw money into
LOL Paul,
I put the extra 1 in there as a tester for Pete, he kept haggling me to put my mod list up, so I thought I'd put it in there to see if he actually read it, well to see if anyone read it. Two months later somone finally spots the deliberate mistake ;) Well done mate ;).
as per sig plus clear side repeaters.alpine head unit,audiobhaan sub and 6x9s(very loud)..
At the moment.
Chip,
Boost Jets,
Race Logic Traction Control,
A'PEXi induciton,
Decatted down pipes,
Mongoose exhaust,
RPS Clutch
Removed HICAS
Soon To Go On,
Uprated turbos,
555cc injectors
Forged pistons,
Uprated Intercoolers,
Dual Intake
JWT 555cc ECU for Dual intake,
Lightened pullies,
Earthing kit,
Stuart
Erm..........I dunno..........
Re-mapped ECU......
Bleed Valves (Big brass screw thingy's each side!).......
Uprated rad........
Autobox Oil Cooler........
Stainless Steel Scorpion Zorst (Twins each side)........
99 Spec Front Bumper.........
Blitz Dump Valves........
Smithy's Stainless Steel Hard Pipes with blue silicon.........
Smithy's Rad Kit - Bottom with Top To Follow with blue silicon..........
Grounding Kit - made and fitted by ME!! (updated pics soon!).......
EBC grooved and pitted discs with 'black stuff' pads all round.....
M's induction kit........
Smithy silicon hoses (anywhere they fitted!) :D .........
Pioneer ICE throughout (all speakers and head unit)......
mStation ;) .......
2 Amps in rear...
12" (I think!) Sub in custom box.......
18" Khan RSR alloys......
Smithy's Clear Side Repeaters.......
Oh, and I Hammerited a couple of things too........ :D
Gauges (to be fitted!)
Steering wheel (on it's way and to be fitted!)
Front And Rear Strut Barces (on way and to be fitted)
I think that's about it really......??!!?
Matty.
Chip
Blitz radcap
Scorpoin stainless zorst (twins each side too Matty!!) but not fitted yet.
Razo Gearknob
H.K.S Turbo timer (Antique model)
......and lots of silly flashy lights!!!!
Profec E01 Boost controller
JD 4 Map switchable ECU
Apexi Intake (soon x2)
GPS Exhaust
Fidanza flywheel & ACT Clutch
Cusco Plate LSD
(Soon) Topspeed HICAS remover
Koni Shocks
Blitz Springs
Full ES Poly Bush kit + Rose jointed tension rods
Carbing Brace
R34 Front Brakes
BBS LM Alloys
Other little bits of stuff that aren't worth mentioning!
MACCA Bud why you spaced your mods out :p Is it so it looks a lot more than everyone else...... LOL ;)
Bodywork:
Strosek wide arch kit
Strosek rear bumper
Custom rear fog lights
Wings West side skirts
Stillen front bumper
Stillen headlamp panel
Rear spoiler (The Z Centre)
Clear side & front repeaters
Rear tailgate spoiler in fibreglass (The Z Centre)
Smoked tint windows
Illuminated rear panel (Smithy)
ZedWorld headlamp upgrade
99 spec rear lights (The Z Centre)
Wheels, Brakes
& Suspension:
AZEV A 18" 8.5" fronts, 10" rears
Front: Skyline R34 Brembo calipers
330mm Wilwood discs
Rear: 3g 10 groove discs
Porterfield carbon kevlar pads
Braided stainless steel brake lines
Master cylinder brace (SE Nissan)
KONI adjustable shocks (GPS)
Blitz super traction springs
Rose jointed adjustable tension rods (SE Nissan)
Engine /Gearbox:
Koyo Racing alloy radiator
Chrome rad brackets
Blitz dump valves with SS hard pipe(GPS)
Blitz induction (GPS)
SE Nissan Intercoolers
Stainless Steel de-cat pipes (GPS)
Mongoose stainless steel cat back exhaust (GPS)
Paul Bailey steel bottom hose
Samco vacuum lines
Blitz oil and radiator filler caps (GPS)
Paul Bailey carbon fan cover
Paul Bailey alloy timing belt cover
Polished SS hard pipe kit (Smithy)
Polished plenum (GPS)
Polished water feed pipes (GPS)
Chromed balance bar (GPS)
Blitz Stainless Steel hard pipes (Smithy)
NISMO Adjustable Fuel Pressure Regulator
Autometer mechanical fuel pressure gauge
Removed EGR's
Stainless top hose with temp sensor flange (Smithy)
Braided stainless steel fuel lines
Stainless custom made power steering tank (Smithy)
Three piece carbon slam panel
Chrome AT Dip Stick
Chrome Oil Dip Stick
Chrome Brake Res Cap
Chrome Rad Res Cap
Chrome Battery Tie Down
Chrome PAS Res Cap
A very big power increase by SE Nissan (top secret mods)
Fast road gearbox upgrade (SE Nissan)
External gearbox oil cooler (SE Nissan)
Interior:
Nismo white dial clocks (The Z Centre)
Carbon clock surround (The Z Centre)
Carbon fibre interior trim kit (The Z Centre)
Red leather trim
Razo gear shift (Smithy)
Razo pedals
Triple A pillar pod (The Z Centre) with :-
Autometer boost gauge
Autometer mechanical oil pressure gauge
Autometer water temp gauge
Autometer X2 air fuel ratio gauges
Momo steering wheel
Blitz Power Meter I-D (GPS)
Blitz SBC ID II boost controller (GPS)
HKS AFR (GPS)
Snap off steering wheel
Pioneer head unit OEL
Focal Xover speakers
Watch the above list GROW in the next 3 months
Freshly rebuilt engine!
Central20 Racing ECU
HKS EVC Boost Controller @ 15 psi boost
Ported and Polished Cylinder Heads, gas flowed,knife edged, three angle valve cut,
Lower Plenum ported and polished
Exhaust Manifolds Ported and polished. With EGT senders fitted
Exhaust Manifolds Wrapped with Heat Insulator
Polished Pistons
EGR disconnected using 300 Block off Kit
AIV's disconnected
Throttle Body Bypass
Thermostatically controlled Uprated Engine Oil Cooler, OEM system bypassed
NGK PFR6B-11B plugs gapped to 0.95mm
Upgraded PTU. Insulated Fuel Rail.
Supplementary earthing cables
Fischer Lightened Pulley,
Short Shift Gear Stick
Redline MT90 G/box oil
OS Gilken Twin Plate Carbon Fibre Clutch
OS Lightened Steel Flywheel
Jun Uprated Clutch Pivot Pin
S/Steel clutch line
NA Differential
Redline Diff Oil
Water channel flashings cleared
Stainless Steel Rad Hose replacements
Redline Water wetter added
Nismo Radiator
1.5kg/cm Rad Cap
SE UpGraded Intercoolers, with bumper Exit ducts and cleared components around intercoolers, for improved air flow
Apexi Air Intake
Complete Decat
Kakimoto X flowed Exhaust
Flat Oval Rear Back Boxes
Skyline GTR33 V-spec Front Discs and Brembo Calipers
Ferodo DS2000 Pads
S/Steel Brake Lines
DOT 5.1 brake fluid
Master Clinder Brace
Lowered 25 mm or 1 inch, for you old fashioned imperial freaks LOL. 2+2 TT Front Sway Bar. 2+2TT rear sway Bar.Polyurethane Tie bar Rods.TSW Hockenheims (tyres hopefully soon to be remedied)
Uprated Horns
SPL detonation sensor
Carbon Fibre Fan Shroud
Clear Rear Side Reflectors
Stainless Steel Armoured Fuel Lines
Polished Plenum
Chromed Bolt Engine Bay Bolt Kit!
Black Leather arm rests with white stitching side and centre and gearstick boot
se monza 2 front
se side skirts
se imola spoiler
paul bailey rear
se quad front headlights
paul bailey rear quad lights
doors de-linned
hiden fuel filler
aerial removed
candy apple paint
se bonnet bulge
side repeaters removed
18" rims
ap 6 pot calipers
343 mm ap discs
groved rear discs
ferrodo pads
braided brake lines
race logic traction control
se rose jointed tension rods
hicas removed and rose jointed
se lowering springs
ap paddle clutch
stage 1 turbos
se boost upgrade
se performance air filters
se remapped ecu
se straight through exhaust
polished and ported heads
apexi turbo timer
cliffod alarm (self start blah blah blah )
s2 interior
momo millenium steering wheel
momo peddals
funny chrome gear knob
ripped drivers seat
2 kilos of fag ash in rear seat
1 arsehole of a driver
Already on:
Flowed heads and inlets
SE Hybrid turbos
Auxiliary injector system
Blitz SBC-iD Boost Controller
Blitz Power Meter iD
Bailey Motorsport Dump-Valves
HKS double front mounted Intercoolers
HKS duel induction system
Stillen Racing clutch
Lightened flywheel
Racelogic Clubman fully programmable traction control system with launch control
Brembo big brake conversion
330mm brembo cross drilled / grooved discs
Pagid RS4 Race Pads
Tokico shocks
Eibach springs
Suspension Techniques adjustable anti-roll bars front & rear
Solid Bushes
18 inch Antera 121's fitted with Good Year F1's
Straight through exhaust with cats removed
Twin powerflow 4.5 inch jap style exhausts
Due to a slight piston problem!! engine is out and the following items are waiting to go on:
Greddy 89mm forged pistons
Greddy forged con rods
Greddy 2mm head gaskets
Greddy emanage ecu
Mine
Stillen intake
SS Decat pipes
HKS ALC
JD chip..........
What about you?
:dance:
:shock: car mats
Decat Pipe
Blitz Nur SpecBlitz id BC
Colder Plugs
413 BHP
Decat Pipe
Colder Plugs
413 BHP
Stuffed into a squashed FROG!!!! :D :D :D
:rofl: :rofl: :rofl: Too True Mark,it could be 2000rwhp but at the end of the day I would rather drive an Austin Alegro :o
  • 3 months later...
Update and still more to add:(
Strosek rear bumper
Stillen front bumper with Nisstek intercooler exit ducts
Rear fin (The Z Centre)
Smoked tint windows
Illuminated rear panel (Smithy's Place)
******** headlamp upgrade
Wheels, Brakes
& Suspension
330mm Wilwood discs
Master cylinder brace (Nisstek)
Rose jointed adjustable tension rods (Nisstek)
Engine &
Gearbox:
Nisstek Gas flowed and ported heads
Nisstek Gas flowed and ported lower intake
Nisstek H Beam rods
Nisstek Forged pistons
Nisstek fast road cams
Nissteksolid lifters
NisstekVernier pulleys
Nisstek Intercoolers
Pentroof downpipes
Pentroof frontpipes
Doolz twin induction
Koyo Racing alloy radiator (NE Performance)
Samco vacuum lines
Polished SS hard pipe kit (Smithy's Place)
Chrome dipstick engine (NE Performance)
Chrome expansion tank cap (NE Performance)
Chrome PS tank cap (NE Performance)
Chrome master cylinder cap (NE Performance)
Blitz Stainless Steel hard pipes (Smithy's Place)
Removed EGR's
Stainless top hose with temp sensor flange (Smithy's Place)
Braided stainless steel fuel lines (Smithy's Place)
Stainless custom made power steering tank (Smithy's Place)
Stainless Steel fuse box cover (Smithy's Place)
DTA Engine Management System
Pentroof Manifolds
Greddy TD05 18G turbos
Border 850cc fuel rail
Interior:
Greddy EGT gauges with warning x2
The Z Centre over clocks pod mount
Red leather trim
Razo gear shift (Smithy's Place)
Razo pedals
Momo steering wheel
HKS AFR (GPS)
Techtom MDM-100
Mac, you havent added your latest mod.........
.......Your MANUAL gearbox!!! :rolleyes:
It's just going to slow it down!!!!
ok my little list
0. Sprayed R34 Bayside Blue
1. Bomex front end
2. Bomex Headlamp Panel
3. AVN evolution Drop forged chrome split rims 17x8" at front 17 x 9" at back
4. Hard Pipe kit s/s
coming soon
5. Chip
6.Boost gauge in pillar pod
7.oil pressure and water temp in "mickey mouse" dash pod
8.C/F spoilery thingamajig
9.Letter from Bank Manager
10. Fisher price Boost controller (about all I can afford at the mo!)
A few bits n bobs ;)
JWT Ecu.
JWT Sport 500 Turbos.
Nismo 555 injectors
Uprated larger intercoolers.
Cybercraft Twin Cone Induction.
Uprated Auto box and Torque converter
13 row Mocal oil cooler
Full Stillen lightened underdrive pulley set.
New PTU,Battery,Radiator,Water Pump, Aircon Pump.
New Temp sender + water pipe.
Adjustable rear spoiler.
Z Centre front bumper with added air vent side pods.
Vented headlight panel.
Cusco front strut brace.
Stillen adjustable Front and Rear Sway bars.
SE Nissan Rose Jointed Tension Rods.
Mongoose Stainless De-cat Exhaust with Quad Pipes
Porterfield R4S pads
Braided Brake Hose’s +DOT 5.1 Fluid
Azev “E” Alloys(8.5x18 front,10x18 rear)
Koenig S5000G Race seats with matching rear seat trim/cockpit trim.
4 Point OMP race harness’s.
Momo steering wheel.
Cruise control switch’s inlayed to top of steering cowling.
Custom 300ZX polished boot trim.
Custom “Z” foot rest.
Sparco pedals.
Clear 99 spec rear lights.
Clear side repeaters.
Illuminated 300ZX rear centre panel.
Privacy class 100% rear,25% sides.
Smithys Stainless Hard Pipes and water pipe(temp boss/sender fitted).
Nearside exhaust down pipe fitted with EGT boss.
Exhaust wrap.
New fuel filter.
Denso Iridium IK22 Race plugs.
L.E.D lights fitted to instrument binnacle for beam and indicators.
New caliper seal kit front and rear.
Push button Start.
“Z” billet alloy oil cap.
Original Fairlady Z pile mats.
New Targa Seals.
New “Z” logo Targa bags.
Targa shade panels.
New front wheel bearings.
Camber plates fitted to front suspention.
Rear boot power socket(12v)with 300w Inverter(240-250v).
PS2/DVD,with wireless controllers
7” Legacy Widescreen monitor with remote.
Smithys Stainless Fuse Box cover with relay/fuse detail.
Oil temp sender/boss fitted to sump.
New centre prop bearing.
Samco lower rad pipe.
Refurbished alternator.
Gold Battery Terminals.
HKS Hyper Ground Earth System with gold connectors.
RAZO shifter.
3 Pod pillar gauge mount with Boost/Water/Oil gauges.
HKS EVC5 Boost controller.
HKS D1 Rad cap.
Apexi SAFC II Limited edition.
Greddy full auto turbo timer.
FSE Power Boost Valve.
JVC Head unit with 12 disc changer.
AutoWatch Thatchham Cat 1 Alarm/Immobiliser.
Tracker Monitor with transfer available.
R33GTR V-Spec Calipers,
DBA Holed/Grooved Discs
Greddy oil temp gauge
Greddy EGT
DTA Stainless brake res cap/power steering cap/water bottle cap
Smithys Stainless centre/side slam panels
Smithys Stainless fuse box cover/with relay/fuse detail
Tony :D
Just read my signature.
Geoff.
ok heres my ickle list so far
93tt red manual;
s/s straight through 6" zorst
arc induction box [for sale]
gab ajustable front suspension
ecu upgrade
boost controller coming soon
lightened crank
veilside skirts with modded vents
bomex front bumper thats fu**ed free to a collector
99spec front bumper on order
99spec rear lights
clear lenses
rear tints
brembo discs fr
mintec pads fr
stern 17"alloys
interior trim in black and red
alumminium dash kit
momo gear shift knob
sparco race pedals
red gear/handbrake boots
sony cd x2remotes
immobiliser/tracker systym
im skint! but want so many more things [like a spoilt kid] :rofl:
Not much really, but here goes:
1. 17'' Gold/Chrome splitrims.
2. HKS Super Drager single exit pipe.
3. Hicas removed.
4. Greddy FATT turbo timer.
5. Pioneer ICE/CD changer.
6. Z-Sport speedo dials (JAP).
7. 3 gauge pillar (no gauges...yet!)
8. JWT Chip.
9. Boost jets......soon to be a boost controller!
10. Chrome speedo rings......in the post!
