smoke
3 days ago i started the car up in the morning then went back in to let her warm up. came back out 5 mins later and there was white smoke everywhere out of both?, when you rev it theres a slight blue colour out of passenger side then when you drive off 1 minute down the road everything s clear. This has only just started this week, i cleaned the bodies out the other week (very black) and everything else is spot on. its an import tt auto with 40,000 miles on her. ive just change the plugs to uk ones today aswell, im a little baffled to what it could be?, the ecu read's clean
Ive read it could be the pcv valves, could this be becuse i cleaned the bodies?
whats the best test i can do?
thank you every one...............
Did you reset the ECU after cleaning the Trottle bodies? To do that you must disconnect the battery for 45 mins or so.
The white some is nothing to worry about if it goes after 5 mins or so.
The blue smoke is oil and could be your turbos leaking very slightly. Nothing too urgent for now
Stuart
yes, mate i did reset the ecu, do the turbo seals go as quick as that? , and it has'nt had any smoke of any colour since i got it 6months ago
thanks for the reply.
