A/C Radiator
Hi guys,
I'm needing an A/C rad for my 92 TT UK. Anyone got one they're selling?
Cheers Darren
i've got one here looking to re-coup what i paid for it £80 inc postage
Labour cost to change can be heavy, if fitting a used one have it pressure tested first.
Jeff
Listen to Jeff, I tried at least 3 known good Aircon Radiators, all were duff, with items such as these and also due to the aluminium nuts corroding to the point that become US, you are advised to spend the money upfront on bringing one in from Z1 or CZP, Trust me , you will save in the longterm, but you should also be prepared to replace more than just the Aircon Rad if you cannot save the fittings when removing it from the system, you should also change the Drier whilst you are at it, and ideally remove the compressor, check it, and refill with the correct amount of PAG oil in readiness to have the system recharged.
Sage advice from someone who has already gone through this.
Any pics Black-zed? Have you pressure tested it?
Thanks for all the advice guys!
it was bought as working, i have applied some pressure to it and it's not showing any leaks. it has one of the ali nuts still attached and one has been removed, i'll try and get some pics early next week, as i'm busy all weekend
