Having obtained an OEM radio cassette and CD player I now need a sub harness to go with it
This is a small separate wiring harness sometimes called a Y harness that connects the two together and then connects to the vehicle loom
A post on a USA website says you can get them from Nissan but I’ve looked everywhere for a part number and cannot find one. The Nissan dealer hasn’t got a clue without it
Has anyone got any spare I can buy?
Matthew
Edited by rookie2767
Added picture
What does the connector socket on the CD player look like? They vary depending on the make/model of the player, for
example a 5 pin DIN connector or an 8 pin connector.
If you PM me your VIN, I will look up the parts database for the part#. However, it may well be NLA and you will need a s/h Y harness or
make one up.
Hi
Thanks for your reply
I’m away at the moment so will post a picture of the rear connectors tomorrow.The din lead is fine, it is the power lead that is missing. At the back of the CD is a four pin power connection. 2x2 arrangement. There is also a separate fly lead with a yellow cable and single spade connector on it. The CD is by Clarion as is the radio.
I will PM vin number tomorrow as well. Photograph shows exactly the lead required. It’s going to be difficult to make one of these as the adaptor lead has a connector that is a plug one side and a socket the other
