up for sale is my zedputer project & amplifier, the car pc is based around a sapphire edge HD3 pc, running windows 10 & centrifuse (i will leave centrifuse on) it's a 1.6ghz processor with 4gb ram, wifi, usb3. also included is a 7" touchscreen built into a radio bezel, could do with a little tidying but it works as it should. there is a intelligent vehicle power supply (turns the pc on with the ignition, then turns it off after ignition is switched off), a usb relay that switches the amp on & off when centrifuse fires up to avoid any bangs through speakers. there is a blue soilel bluetooth adaptor which also works through centrifuse for music streaming and with the addition of a mic could be used for handsfree calling.
through apps and a gps module this system could have sat nav added as well.
the amp is a mutant MT1204 4 channel amp 60w per channel, i used this bridged for the sub and stereo for front speakers. i have also included the power cable for the amp to run from the battery but you would need to source an earth cable and remote cable for switching.
looking at circa £190 for the lot including postage,
No posts to show
