Hi I'm after a good condition fuel tank for twin turbo UK SPEC LWB Z32, my tank has a leak ,
just seeing what anyone has and price , drop me a pm or post etc, cheers
I have a lwb na (JDM) south London if you need and are the same, I'm fairly sure they are just the pump is different. It has some surface rust but the inside looks clean
cheers i just sent you pm:thumbup1:
Tanks are all the same, grit caught in the rubber coating of the tank straps is a problem as it slowly grinds pin holes into the tank.
Mostly UK zeds were effected more than import so best to look for an import one, make sure you have the correct pump though, use your own if not sure.
Jeff
Edited by JeffTT
Tanks are all the same, grit caught in the rubber coating of the tank straps is a problem as it slowly grinds pin hold into the tank.
Jeff
Well that's a relief, the tank straps rusted off :)
