Hi all,
I've decided to sell my AEM ems uego series 1 stand alone ecu which is plug and play in to the 300zx OEM loom.
This ecu has a Base map on it but I wouldn't advise using it for more than a start up if the engine specs are similar to what I had.
I have the ECU which is the later uego model as well as all the sensors required. MAP sensor, Air temp sensor and wide band AFR.
As some of you know I went to have the car mapped with this ecu that led to find ou that my engine wasn't built correctly.
Soon after that I stripped the car and most of the parts having just been sitting.
£600 delivered.
I do also have supporting AEM uego link guages also that link to the ecu.
I have 1 Wide band guage and sensor! This allows you to measure the AFR ratio's for both banks. I also have a series guage that relays all the ECU information to the guage! You can set alarms etc to monitor all of the engines reading's. Oil pressure, water temp etc etc.
£200
Thanks Dan
