Any sparkies on here? urgent help
  • Replies 30
  • Views 787
plus if you not got any earths then i would get it rewired,!!! if i lived closer i would come sort it out for you.
hi you have 4 reds and 3 blacks, 2of the blacks are loop in/out neutrals.looks like they have used 3 reds as 2 way switches, leaving you with a red and a black, they are your switch wires to the pendants,1st find these 2 wires. after that pair the other 2 blacks together. next separete your remaining reds these should be connected to your switch,your live red to common, the other 2 too 1and 2.now connect your switch wires{red and black from the start}to 1 and 2. lol sound easy. thats the easiest way to explain it...hope this helps..
dont think its as easy as that as he says he has a red&blk twisted together? & only one black in the other switch, need to be looked at & tested dont think it can be solved on here to be honest!
you need to start from the begining ,someone mustve been messing around with it, forget what he has got at the moment and start from stage 1 , piy not in glasgow its a 5 mins fix..
I had the same kind of problem, finished up getting an electrician to come and sort. He said the 2 switches where fed from 2 circuits, upstairs and downstairs. Hope this helps, but I would just get an electrician to come and sort.
