protoj · Tuesday at 18:48 4 days
Hello.
I was wondering if anybody knows of a garage in scotland(for my BMW) that would obtain an m3 engine and convert my 318 m3 replica into a genuine m3? ovioulsy new gearbox etc need aswell. Anybody kow of such a garage?
cheers
craig
.........just need something quick:rofl:
