Morning,
The lock on my back door is playing up, the spring in the handle has gone. Not sure what the type of lock is but it's in a UPVC door, takes a euro cylinder and the mechanism runs completely up the edge of the door. It jas 4 hooks that come out when the handle is raised as well as a straight bar in the middle which shoots out (as well as the latch).
My question is can I just change the actual lock part or do I need to get the whole mechanism from the top to the bottom of the door?
Vijay
If it's just a case of the spring in the handle, then a new pair of handles
will do the job. Does the lock work ok apart from the handle?
Some handles have a plastic spring clip inside the handle, could try
turning this round.
Got any pics ?
No the handle doesn't have any springs, they just turn 360. Pretty certain the spring part is in the lock itself :(
Ah, i see.
A good locksmith may be able to strip the lock and replace the part.
Failing that, then yeah you're gonna need a complete lock, it's called
an 'espagnolette' locking system, a specialist job i'm afraid, not the
type of lock you can get in B&Q.
Cheers bud. At least I know what I'm looking for now :)
