just bin playing my new left 4 dead and it just died like a power cut. Motherboard light is on but nothing will fire. I think it may be the power supply it's only 4 months old a Red PC power one and was nearly £125 on its own. I am so fecked off just hope it's not the mobo or taken my quad out with it :headvswal:headvswal:headvswal:cry::cry:
Edited by 8ace
  • Replies 81
  • Views 1.4k
Will you just take out a psu from another desktop then and try firing up your mobo that you still have no idea works or not lol:headvswal
when i get round to pulling the board I will try one of my others in that case on that psu it's far easier than trying to get the psu out of that case it's a right pig
i'll rma my old board now for repair can't wait should be able to pick new board up tomorrow.another quick question will vista home prem oem be ok with registering with this board as I bought and installed it on my old board. Does it register your components like xp used to?
They have got a bit picky about using oem stuff now, i'm not 100% sure to be honest. Plus why on earth would you want to use vista running specs like that! Stick with XP!
sorry think i threw a bit of confusion in there. I already had vista running in with my old board will it still work with the new one or have i got to buy a new copy. I'll find out on sat if my board comes
If its the same board model and nothing has changed apart from the replacement of the motherboard it should still work, its sometimes wont work, sometimes it will :P
Good luck with it
it's a different model board. microsoft are c##ts i've only bought vista 6 months ago £80 for 6 months use arrrrrrrrrrrggggggg
if my existing copy don't work I'll phone microsoft and argue the toss with them 1st but will defo be the 64bit next as it support more ram too
oooh sorry it was retail vista I have not oem
it's here :D arse in gear tomorrow and away to go
c#nt still won't boot with new board in.Local pc shop gonna get a foot up the arse monday they tested it and said board was faulty and power supply was fine.
your kidding me :O, did you connect the front panel connectors up correctly?
iv'e got 2 600w psu if you want to try them
cheers lampy for the kind offer but got it running now looks like the old board probably ok the twats failed to check......wait for it................ the legendary asus q connector and it's f@cked a 30p item they shall feel my fury on monday this is the culprit
Oh dear mate :( Wanna game of something now? Bet you really want to play a few games :D
i swaped the switches to see if that was it and changed to q connector and is posting now just need to find stock volts for xms2 ram as asus boards seem to pick um up at 1.8v i think they're 1.95 and always crash in windows unless it's upped from default anyway some pics
soon as i get im up to stock volts can't wait for a game
iv'e built a cople of pc's from asus barebones systems and always been ok apart from one wasn't vista compatiable. Iv'e got an XFX 780i board now and i have so say they are fantastic and the support is out of this world, they mailed me after they gave me some advice for a problem i had after they gave me a solution jnust to check everything was ok and that i was still happy with the board, second garphics card wasnit sittting right as a wire was in the way as case it a bit tight
big buggers aint they .. have to take the pci retainer off my case to get it in :headvswal 1.9volts for the corsair i'm off to boot windows cheers all for help yuv bin great guys tanks.............:)
