Expansion tank probs
Evening all
My rad doesnt seem to be drawing coolant back when it cools. The expansion tank often overflows slightly after driving and when it is cold, the level in the rad is rather low. I top it up before every drive and the level in the rad is always the same, be it a 10 min trip to the shops or 150miles to the girlfriends.
I think my HD is on its way out as I have combustion gasses in the coolant, but no water in the oil or oil in the water. :rolleyes:
Could it be something as simple as the rad cap or is it more expensive?! :wack:
Thanks!
Andrew
Buy a new rad cap first and if the problem persists investigate the HG?
Have you done the test for exhaust gases in the coolant. If they are present then there is only one concluion to come to.
i think my expansion tank is bust so my mate is going to look at it today. easy is this to get to, i think he is going to be stripping the wing down. possibly a plastic weld on it or something
Membership No 0780
INSURANCE GOOFA
You may be able to do the old trick of a plastic bag in it.
