Easy way through???
Hi - Can anyone tell me if there is an easy way to run a pair of wires from the engine compartment thro to inside the car? Cant tell you what its for or no one will tell me due to the tackiness of this particular mod!!! :cool:
Copied from a post by blackmagic ..do a search thers loads of info there
hope it helps
steve
There are at least two that i know of.
One either side.
Down by the foot well on the bulk head
about half way up the wing level.
I found (well krsmayo did) the passenger side easier to thread through as theres so much other stuff going through the drivers side.
make sure to use a flexiable non permanent sealent if you leave a gap...otherwise damp and water may get in
led washer jets? :hyper:
electric dump valve sound? :hyper:
electric supercharger? :hyper:
:confused: :rofl: :rofl: :rofl:
anyway
firewall wires link
I recommend Method 2.
There you go.
I went near the battery, through the wing (peel back plastic inner arches) and go in near ecu near passengers feet.
Compleat PITA but I couldnt go through the bonnet release catch.
Thanks guys! Off now with my coat hanger & vaseline! Will post succsess or failiure later!!
Christ, there's no need for that. When are you going to work on the zed instead? ;) :rofl:
