im shockerless
just ordered my new shockers from luke, wanted upper and lower arm bushes aswell but out of stock for a month. was told that my rear wheel wobble was most likely my shocks anyway. well ive taken them out and cant see how this would cause it. if anything it looks like it would be the bush in the hub the shocker connects to that would cause the prob. put the wheel back on and felt for movementwithout the shocker and its exactly the same. any ideas anybody
yes mate both sides
well mine seams to wobbel side to side any way checked all suspension no play found out its sub frame bushes that are fooooked
mine is diff. if you wobble the wheel it turns through about 5 degrees. ive got the hicas hub bushes to replace. doing the shockers. does anyone know if its common for the bush in the hub that the shockers to go in to go? can it be replaced?
hicas arms?
Daveman
when people say hicas arms do they mean the bushes? or the arms them selves
i would say check the hicas arms and the bushes they bolt to most likely to be the bushes though if not maybe your hicas rack is fooked
i'm guessing thats what is causing your wheel wobbles you should not have that much play in them if you need hicas arms contact mike feeney at mjp in the traders section he should be able to help
