glove box lock removal
how the hell do i remove the glove box lock, got it all dismantled but I cant see how you get the plastic bit out that hold the barrel in place?
I seem to remember you use the key itself. Put it in the lock and pull or something like that. It's been a few years since I did that and I only stumbled on it by chance. I swear that's how it works but I may be wrong.
The barrel just slides into the plastic surround - it's not even an interference fit. When you remove the 5 screws from the rear of the handle, the whole assembly (including the lock) should just fall out.
The plastic trim around the barrel has two notches on the reverse that clip onto the back of the glovebox face itself. You need to remove the glovebox itself from the face first :)
LOL, I read that then just pushed it out! typically looking for some over engineered mechanism:hammer:
thanks for quick reply!
