Tender springs and spring rates
Could I have sone technical input on removing the tender springs and what spring rate to run. The tender spring at the rear takes up about 25-30mm, so at max drop the car is just kissing the arch visually, I would like to be lower but the tender is holding that back. The spring rates are from a skyline and I couldn't guess what they are, also the front springs need replacement to be compatible, so it makes sense to replace all four, so what would be a good suggested spring rate and front rear ratio for a car which is predominantly a road car but will see light track use? I already have stillen ARBs and have tyre sizes of 225/40/r18 and 265/35/r18 at the rear, I'm not looking for it to be some ultra twitchy go kart but a well planted and predictable car.
No posts to show
