auto to manual
Hi all,can someone send me a list of all the parts needed to convert an auto to a manual on tt.also what sort of time are we looking at re labour for doing conversion
Doing it yourself, or paying for it? I only ask because the time aspect will vary wildly due to experience.
Its worth going to one of the few experienced mechanics we have on here mate, you know their names, if not check the trader area.
Don't rely on any old garage or apparent gearbox specialist as you will probably be paying them to learn.
Gearbox
Gear lever linkage
Gear lever bushing
Gear knob
Gear knob dust boot and securing bracket,
Clutch pedal assembly
Manual break pedal (unless you cut your Auto break pedal down to size, then all you will need is the break pedal rubber)
Clutch booster (if Twinturbo)
Flywheel
Clutch pressure plate
Clutch housing
Clutch fork
Release bearing
Manual pilot bushing
Front half of propshaft
Clutch master cylinder
Clutch slave cylinder
braided clutch line (optional but better)
Some wire to wire the gearbox into the car and pin 44 on the ECU for the neutral switch
A bit of heavy duty wire to bridge the starter relay in the drivers side wheel arch.
Gearbox oil. fully synthetic GL-4, 75W-90
All associated bolts and nuts.
Think thats about it.
The associated bolts of particular importance
Flywheel Bolts
Clutch cover bolts
Bell housing bolts ( not all the same)
Rear engine crank seal ( better to do it now)
Jeff
