is rear camber ajustable on stock car ?
is the rear camber ajustable i read online it was and some were else it wasnt ?
Yes but not massively. There's an elliptical bolt/washer that controls the camber angle.
ok as you my have seem my car is puling left the rear left camber is out and the fornt rite camber is out to
Then you need to take the car along and have an alignment done buddy. Is it stock hieght or lowered?
its been done toe is fine front and back but camber is a bit out
yes but the stock front cant be ajusted so am going t get a ajustable front camber arms. the back camber may ajust to were is needed with the way it is am the min would this be out enuf to make car pull left
Quite possibly yeah. Is it stock ride height has it been lowered? If it hasn't I'd be surprised its that far out and boo looking for damage/worn components.
all the bushings look fine .with the ajustable tention rods would this let you ajust caster to
yes adjustable tension rods would let you adjust the caster, when fitting them, start at the same length as the original tension rods, and ensure both are the same length.
