99 spec front indicators ( side lights )
Do the 99 spec front indicator units have the side lights built in to them ?
as with my new bumper i have removed my fogs
They are in the spotlights,
Paul
Edited by 300_zedx
wrong answer, correct answer now posted
"phew" .. started to panic
i know i will need new plugs but i can sort that out
Hi Mark, I'm not sure this is correct, I have no battery on the car to check this out, will try and confirm tomorrow.
Paul
No they dont, sorry Paul, i had to put some leds in mine to create a sidelight as i too have no fogs. There is another method of cutting out a bulb holder hole in the blank where there should have been a side light, you will see what i mean if you get one apart.
ok thanks for the info ... i can put some LED's in my ones that will be easy anyways
Mark
Edited by MarkDerby
I used normal 5mm white leds, i placed a 470 ohm resistor on each one, as i didnt want to lose a row of three if wired in series.
I drilled 5mm holes which makes a nice tight fit, then hot glued and sealed the rear of the leds/wiring
Edited by groover
Done it .. i used two 3smd/led light strips in each unit ...
so theres a total of 6leds and all will run independent
Cool, the only reason i didnt use the strips is the spacing of the leds are too far apart for the effect i wanted.
i stagged the leds over both strips so theres led about 5>7mm apart
looks all right i will try and a pic
Mark would this have anything to do with the issues you have at the MOT station, about your lights?
nope .. not even fitted yet ... bumper/lights are still in my garage ready to be fitted some time this week
its not on the car yet ...... but in that pic u can see its got an Flar edge to the bumper now
Yeah already noticed that. done a super job blending them in :cool3:
I know you have done this now but can we use later combination flasher side lights that have a us spec side light or do the sidelights have to be to the inside of the flashers doing away with the sidelights in the fogs and if so where does the the power come from to use them? is there a socket in the wing or taken from the fuse box or a different wiring loom from a Jap
all the wires/plugs are all there
Jap
Indicators only
Side/Fog
US/Uk
Indicators/side
Fogs
thats the same with all Bumpers
unless Fog light units have been removed
US/UK indicator units will have to be used
99 spec bumper needs different indicators units
and dont have any side lights in them
this is why me and other ppl have fitted LEDs in them
when No Fogs are fitted
Hi Mark, I have the later indicator/side light or marker with 3 wire connector in the unit so I have the side light but it is not activated as the sidelight iin the fog is used, I am asking if it is legal to use this instead of the one in the fog, my other early zeds have a 2 wire connector in the flasher so I would have to do the lcd fit.
yep its legal ... u can wire them both up if you want to ... i'm not sure how its wired in the fuse box on the car
but if its more problems on the fuse box end .. u can cut in to the side light wire on fog and join it up to the Side light holder on the
indicator unit
Mark
